Here comes MODUS!!
However, it's not that remarkable.
10 amps at 48 volts is close to or more than 40 amps at 12 volts.
4 amplfiers on a 12v system, at 40As each, yeah, that's a lot of current.
I mean, you can only convert so much power, and believe it or not, 100% efficeincy is the maximum theoretical conversion.
That said, there are some new high-efficiency chip amps from Fosi (I just acquired one), and Helix has a new line of chip amps that are exceptionally clean, albeit almost sterile in reproduction.
I still think that conventional board designs with the use of high-efficiency chip-driven fast switching on-demand variable power supplies, along with GanFETs, have a good chance of being the next big thing.
If it is reasonable, sounds as good as one expects, and does more for less, bring it on!
ThxOne
Premium Member
Staff Member
ThxOne
The United States of America
