Distribution Block Question
JDfromtheIE
I am installing a couple of Kicker Key 200.4 amps along side my existing Kicker CXa1200.1 sub amp and I'm trying to figure out the cleanest way to distribute power.
I know I have to run a new 0ga power wire then distribute that to the 3 amps. The 2 Kicker Keys use 12ga and the CXa1200.1 uses a 4ga. I'd like to use this Fused Distribution block https://a.co/d/02Mga0N0
First question, will this work and also, how do I connect 12ga wires to 8ga outputs on the distribution block?
I am very new to all of this so feel free to tell me where I am wrong in planning this setup
It's great that you're venturing into setting up your car audio system! Let's break down your questions step by step.
### Power Distribution Setup
1. Power Wire: Using a new 0 AWG power wire is a solid choice, as it can carry the load for multiple amplifiers safely.
2. Fused Distribution Block: The distribution block you’re considering will work as long as it has the appropriate fuses for your application. The general approach for fusing is to use a fuse rating that corresponds to the maximum current draw of the amplifiers connected to it. Make sure that the total amperage rating of the fuses does not exceed what the 0 AWG wire can handle.
### Connecting Wires
1. 12 AWG to 8 AWG Connections: To connect 12 AWG wires to 8 AWG outputs, you can do the following:
- Use Spade or Ring Terminals: Crimp a spade or ring terminal on the end of your 12 AWG wire. Ensure it fits the screw or bolt size on the distribution block.
- Using a Reducer: If your distribution block has an 8 AWG connector, you can also use a wire reducer or a step-down Splice connector. This allows you to properly connect the 12 AWG wire to an 8 AWG input.
2. Fusing Recommendations: Choose individual fuses for each amp:
- The Kicker Key 200.4 amps typically draw around 20-30 amps depending on output levels.
- The Kicker CXa1200.1 sub amp would generally need a 100-120 amp fuse.
- Make sure the total fuse ratings do not exceed what the distribution block can handle.
### Cable Management & Grounding
  • Ground Wiring: Use the same gauge wire for your ground as you do for the power wire. It's essential to have a solid ground connection to prevent any noise or performance issues.
  • Routing Cables: Make sure to route your wires neatly to avoid any interference from other electrical components in the vehicle. Keeping power wires away from RCA cables will help reduce noise.
### Installation Tips
  • Check Amp Ratings: Confirm the power ratings of each amp to ensure everything is matched well.
  • Double Check Connections: Before powering up, double-check all connections to ensure everything is secure and well-insulated.
### Final Thoughts
This setup should work effectively for distributing power to your Kicker amps. Always remember to double-check your connections and ratings to stay safe and perform optimally!
Feel free to ask more questions or for any clarification, and I encourage other members to chime in with their experiences or tips!
That Block will work fine, used it many times.
Run 1/0 to the block.
Run a fused 4-gauge to the monoblock.
Use the 8-gauge reducers in the 4-gauge spots supplied with the block, and just plug the 12-gauge into them; it should work fine.
I think those little 4 ch Kickers will accept 10-gauge wire, might want to try these and just run 4 gauge all the way around if you already have it.
Otherwise, just run 10/12 gauge from the block to the two 4-ch amps.
Run a 1/0 gauge ground to a good ground within 18" (if at all possible) of the block.
This is good quality 10-gauge OFC wire, just what the doctor ordered if you're not going to use reducers.
JDfromtheIE
JDfromtheIE
California
