Current events discussion
Here we go with a bunch of goalpost moving, spins and bullshit.
We were specifically talking about using a lift. I have proved that you don't have to use a "lift" to gain access to the underside of a car. Smart ***.
You said you never had to put your car on a lift, as if it indicated something negative about MY car being on one of my lifts.
So you used ramps and jackstands, and crawled in the dirt.
Congrats?
I am going to ignore you because you aren't asking a question here but are being a smart *** instead.
Oh? Nothing to do with the fact that you tried anothe of your "gotcha" moments by "correcting" me, only to find out you fucked up your "correction", again?
****! I know this already. Stop trying to teach me shit.
If you knew it, you wouldn't have claimed you put it on to increase boost on your ZX.
My Turbo was a 5-speed. Which is why I also told you they come with T5 transmissions.
Didn't one of your pictures show a T-handle shifter with a straight gate?
Again, something I have told you twice now but you want to carry on like an *******.
What the hell are you talking about. You made a comment about you not hitting the fan. Why would you when you don't have to reach down in there with a running engine to check or adjust timing? Are you stupid or something?
That is something you might want to ask yourself.
Again, you are carrying on just to be a ****.
So YOU **** up agian with your "gotcha" attempt, but I'M the **** for pointing put you fucked up?
Ironic.
Spell correctly *******.
c-o-r-r-e-c-t-l-y a-s-s-h-h-o-l-e
Did I get it right?
You said boost controllers were all manual. Electronic is not manual.
Who do you suppose is pushing the button on the controller to select boost level?
Who is setting the boost parameters?
Robots?
I increased it to 12+psi. Why Rob, why would you increase boost pressure?
A terrible attempt to spin away from another of your fuckups.
Why did you think a blowoff valve increased your boost? Why Michael, why?
Again, keep it going ****. I bet you mom was a **** too.
Spell correctly, *******.
No, you are just being a child because that is all you have left in life.
Ironic.
Meaning a real mechanic can do it on his back.
So you used ramps and jackstands, and crawled int he dirt.
Congrats?
Thanks.
I had ONE auto, the gold car and TWO manuals, the brown car and the Turbo. Try to keep up.
I will think about it.
Ironic.
****. Iconic.
Did I get it right?
Close.
Robots?
The electronics in the device.
Ironic.
Correctly. Iconic. ****.
Man, how can a person need to be right so much??? Electronic Boost Controller. Rob - "No way man, it's manual."
Who selects boost levels while you are driving?
Maybe that other guy that posts under your username? That would mean it's automatic, right?
If someone else moves the shifter, then your 5-speed car is now automatic, too?
Hep peckerhead.... This is a manual/mechanical boost controller. It uses a screw, a spring and a ball bearing to set boost pressure. You set it by twisting the screw one way or the other. This increased pressure on the ball, increasing boost or lessens pressure on the ball, less boost. This is the design I used.
This next one is electronic... meaning it controls the boost electronically.
Jimi77
Premium Member
CarAudio.com VIP
Jimi77
Denver, CO
deez283
