Current events discussion
I don't see any of those amps having multiple outputs.
Can you show me a circuit diagram where a mono amp has multiple outputs?
Calling a connection an "output" doesn't make it an output, any more than saying a non-amplified sub driver "puts out 1,000 watts" makes the driver put out 1,000 wats. Use your brain.
But the label said 2,800 watts, so it must be accurate and true. Right?
Duh.
See what I mean? I gave him exactly what he demanded and he says NO. I do not accept that therefore it does not exist. Just because he chooses to ignore the nomenclature other people use and runs with his own terms by default everyone but him is wrong.
Simply claiming you did something doesn't mean you did it.
You gave a schematic that doesn't show a mono amp having multiple outputs.
You gave a schematic showing a balanced amplifier set up.
A balanced mono amp does not have multiple outputs.
An expert guitar and amp builder such as yourself should know this
Your problem is you ignore reality to spite your face. Just so you can continue to argue. The ******* diagram/schematic show multiple ******* outputs even if your ignorant *** refuses to call them outputs. They are in fact OUTPUTS.
It's a balanced setup, you dummy. Do you not know what a balanced setup is?
Schematic symbol for an amp. They don't have a seprate symbol for one with mutliple outputs, becasue it doesn;t exist.
Find me an amp symbol that shows multiple outputs.
Be quick about it.
Be quick about it.
Argue all you want. You are douche bag who has to be right about everything even when he is wrong. Be quick about that *******.
MAGA Winning!
Jimi77
Premium Member
CarAudio.com VIP
Jimi77
Denver, CO
ThxOne
vegang
    Jul 1, 2026
vegang
    Jul 1, 2026
