Current events discussion
So I'll ask yet again:
JUST SHARE THE SCHEMATIC OF A MONO AMP WITH MULTIPLE OUTPUTS DIRECT FROM THE AMP AND I WILL ADMIT I AM WRONG.
For the how ever many-eth time.
Repetition doesn't make fact, kid. Hitler was wrong, and so is Trump.
You should look for better mentors.
This diagram shows ONE output from each amp.
You can solder 10,000 wires to that ONE output for all I give a ****, and it will still be ONE output.
How many "outputs" are on this car battery?
Is it one 12V output? Is it two, since it has a big post and a little post?
Is it four, since it has a big post, a little post, and two wires connected to the little post?
Is it only three, since the big post is empty and two wires are coming off the little post?
What if 5 more wires are connected to the big post?
Since each wire is 12V, they must be 24v when paralleled, right?
Tell me: HOW MANY OUTPUTS ARE ON THIS BATTERY?
The nerve you have is just crazy out of control. You demanded it, I showed it to you several times, you still say no and argue. There are 24 outputs on that mono amp. Don't argue with me about it. Go to their website and tell them they are wrong about their product and how they label their schematics.
So, neither of you are able to produce a schematic of a mono amp that has "multiple outputs".
It's such a common item, why can't you just find a schematic?
These are schematics two different amplifiers.
Tell me the number of outputs on the top amplifier, and the number of outputs on the bottom amplifier.
lol You're stupid.
Says the guy who claims mono amps have multiple outputs but STILL cannot provide a schematic to prove it, and tries to spin away from his failure by complaining that "IC" and "chip" are used to describe the same thing.
So, how many outputs are on the car battery in the picture I shared?
How many outputs are on each amp in the schematic I shared?
How is it that someone as smart as you can't provide such a common schematic?
Why can't you tell me how many outputs there are on the battery and on each amp in the schematic?
Each amp is 15watts at 6 ohms. What is the wattage output on the top amp with one 6 ohm speaker attached?
What is the wattage output on the bottom amp with an 18 ohm speaker connected to each endpoint?
*The negative leg of each speaker is connected to ground, as it would be in a traditional amp design.
You are the one denying facts. Denying proof.
So you failed yet again.
Just add it to the long list of bullshit you claim and can't back up.
ThxOne's "mono amp with multiple outputs" design.
No wonder you recommended both a linear and audio taper potentiometer to do the same job.
I'll go ahead and take it that this is another of your bs claims you can't back up 😉
Well, you STILL haven't provided a schematic of a mono amp with multiple outputs.
That makes it a bullshit idea.
Twice as bullshit after you tried to say an IC isn't a chip, or vice versa.
Failure.
Where have I ever stated that?
And more to the point you already claimed pyramid did just that...maybe you should provide a schematic to back it up...
Jimi77
Premium Member
CarAudio.com VIP
Jimi77
Denver, CO
ThxOne
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
