Please Suggest me Sub & Amp Combo Based on My Music Taste
NVX has really high quality equipment at a really good price. I would recommend 2-10" speakers in a ported wedge-shaped box. Face the sub and port backwards. Also, remove all the sound padding on the rear deck and put baffles over the rear deck speakers. The baffles will protect the speakers from the pressure of the subs.
Wire the subs up for 2 ohms.
Op had a dual 8 CStang enclosure before, ported may not address what he's used to or wants. Tlines are a once bitten thing... the low power, bandwidth and output usually spoils users. Check Diyma for threads and discussion about pros and cons. Tuned and setup correct a Tline only needs levels and crossovers set. Even an marginal driver performs well above Fs. I never tune lower than Fs myself as a 1/4 octave tuning at 50hz in car should dig deep and flat (25hz?)
Oh I can recommend 2kw on a set of capable 10s but Op has been around, overthinking everything and not ready to buy anyway.
Again "admin" I'm finding myself limited by site messaging...
To Op...
Of course I model my enclosures. BB2 pro and Winisd but Winisd and Torres work for most so thats my go-to. I gave up on Termpro and Hornsrep awhile back. Too user intensive for little return. Available space and driver choice is the determining factor in any design, for example never design a 4th for about 90 ebp subs or above, Ebp has an effect on those 3 pesky laws after all. Well... some roll that way I suppose but peakiness and delay aren't my thing.
I'm not sure if I'm following you. He asked for tight deep bass, and if he's listening to Lil Jon, then he's going to need some depth.
If he had 8's before, then 10's would be better. You mentioned he might not want a ported box, but you designed him a ported box for 6's. As for tuning the crossovers, I didn't mention anything about that.
So, you're saying he's not ready? That's a normal thing. I hear it all day. "What would you get if you have a $2000 budget?" At they end, they don't have anything near $2000 saved up for a system.
So, you're saying he's not ready? That's a normal thing. I hear it all day. "What would you get if you have a $2000 budget?" At they end, they don't have anything near $2000 saved up.
munchy_cool
Junior Member
munchy_cool
FL
shredder1
