2024 kia sportage radio wire diagram
Heath Stevens
Hey y'all
I just purchased my 2024 kia sportage and of course I removed all my audio equipment from my previous car. I'm trying to get everything now in to my kia. But I'm not changing the head unit because a 2din will not fit. So I purchased an XLCA2 two channel line out-put digital bass enhancer. The only issue I'm having is locating the radio wire diagram to tap into for this line output enhancer. Can anyone help me figure out what the rear factory speaker wire colors are? I've searched, no luck. I may have to just remove the door panels to take a peek but trying to illuminate that if possible. Thanks y'all ✌️
  1. Not right now
If removing the radio to take a peek at the plugs is not too hard, you can see if this harness will work for you.
I went ahead and removes the door panels and looks like the 2024 is same as 2023
Rear Left
Yellow + Brown -
Rear Right
Orange + Gray -
And you can locate them under the trim ob the drivers side door jam. Just be easy exposing the wire harness. Don't want to damage any wires. And it also appears that the speaker wires are twisted together.
Thanks everyone and I hope this helps others. 😁
Rear Left
Yellow + Brown -
Rear Right
Orange + Gray -
Also looking to splice into those speaker wires ,I hope the 2024 Sorento has the same color pattern
Heath Stevens
Heath Stevens
Mississippi
Fred Brunner
