New head unit suggestions
Corsair714
Hello all,
I've been researching getting a new head unit since I am having some difficulties with the one I have currently. Looking through the forum it seems like a lot of people would suggest Kenwood which is what I currently have. I am just hoping it will actually work this time.
Specs I want
  • Single din
  • Clean preamp output signal. 5v or higher preferably
  • Enough outputs to give a signal to my amp for front, rear, and sub.
  • CD player
  • USB and Aux
  • Budget is about $200CAD ($150USD)
  • I am not particular to any brands, I just want something affordable and reliable.
Considering
JVC KD-T925BTS
Kenwood Excelon KDC-X305 (basically what I already have)
You're going to lose the front or rear speakers if you hook up the subwoofer. Plus you'll need a low-pass crossover for the subwoofer. Might be front/back left or front/back right. Or just two fronts or two rears. Not sure what your car is. But it won't use all the speakers. You'll have to check the diagram on your car radio factory cabling for this setup.
Mitchell fosgate, are you the same guy from Hawaii that was on here a couple years ago that "read all the books" but has no what he talking about? Or did you guys just take the same short bus to school together?
different guy. You are from Canada? I'm from you guys. I like electronics too. I place electronics all in the same category. Including Car Audio. Just that I find it fun to change car radios. I think becoming a technician when you're something else, another profession is really fun stuff. So I'm serious about car audios. Why do they need a mid-bass crossover for some side door speakers? And where do you hook up the wires? I think that kinds of stuffs is fun. Without burning the speakers.
Mitchell, every answer that I have seen you give on this forum has been wrong. Including this thread. The Jvc stereo that the OP linked to has six rca outputs. Two for front, two for rear and two for subs. So why would he lose speakers if he connects the sub?
Frequencies to the subwoofer is lower than the front and rear speakers. Using an amplifier, the frequencies would be smaller entering in it. So the drivers from the side doors front/back will be given first choice. Frequencies. They will not be the same as the subwoofer. The Driver for the subwoofer is bigger because it covers larger surface area and demands lower frequencies to run it. By using an amplifier with an LOC doesn't mean the side door drivers will function properly. It receives signals from the amplifier and out to the speakers. LOC may not do the job. 4 ohms on all of them. Assuming.
You already admitted you were the same guy in a different post! Guys you do see his signature and profile status right? More can be done if needed.
I've been reading these word salads awhile now. Entertainment is where ya' find it I suppose but... advice should be useful and yours seems aimed more towards proving your lack of knowledge or idk what?
Making this board look bad?
Mitchell,
Shhhh..... Let the professionals take answer the questions. There's nothing wrong with sitting back, listening, and asking a bunch of questions on your own. That's how I learned, and I have built dozens of crazy systems.
Corsair714
Corsair714
Cold Lake
huberoy123
NorthFramingham
    Jun 30, 2026
