Winners only.
You haven't even attempted to answer MY questions you sarcastic assshole.
The answer that I gave proved you wrong. Is that why you consider it not being an answer to your question?
No matter how you try to spin it, claiming your mono amp is internally bridged with multiple outputs because it has a multi-position terminal strip for speaker connections is wrong.
An output for an amplifier is the number of singular channels it amplifies. Mono means of one. A mono amplifier is one channel. One channel is one output.
Go online and search for a multi channel mono amp. Let us know what you find.
Bullshit Rob. Just answer the question without all your misdirection and question avoiding tactics.
How would you connect the two positive terminals together on this amplifier to make them one terminal?
Such a complete and utter piece of shit, Trump is.
Pure garbage.
As are his followers.
So I went to this website... nothing but a bunch of pop up ads and other related tracking ads. Sometimes I forget just how much crap is stuffed onto a webpage. Thank you ADP and Ghostery.
What was the point of posting this Rob? To show yet another site that post stuff for views? Why not post their coverage of Biden calling LL Cool J "Boy"?
Trump is not responsible for Jan 6th. The Democrats with Pelosi and all her minions are to blame.
Right Trump gaslighting millions of people into believing the election was being stolen and then having them gather in DC and then telling the march on down to the capitol and fight like hell, etc had nothing to do with Jan 6th. It was all Pelosi & Company.
It's no longer a matter of the two major parties running on "the extremes;" both parties are running on delusion at this point.
Do you think ALL of America is just dumb people with no brains? I am sure that's what the government thinks but it isn't reality. People watched the elections and followed along. At that critical moment, when Biden was well behind mind you, America went to sleep knowing the next President was Trump. Do you know why? Because the counting was to stop at a specific time and at that time Trump was well in the lead. Some how after America wakes up Biden is the man!!! It was a Christmas miracle or some shit. Counting was supposed to be done for the night but some how overnight Biden had 81M votes.
Something fishy was going on and America knew it.
I wouldn't. They are on a bus, which means they are already connected to each other. Effectively, they are a single connection.
Misdirection and avoidance is what you are doing here to try to prove a mono amp has multiple outputs.
The premise of connection these two terminals that are already connected to each other on the bus is ridiculous.It'd be like putting a jumper on a speaker wire that is still in one piece.
A mono amp doesn't, and never will have multiple outputs, no matter how desperately you want to try to spin it.
An output on an amplifier is a channel. A mono amp is a single channel device.
Mono=ONE.
They are TWO individual parts installed onto that amplifier. To "connect" them together they are installed onto the circuit board and secured in place. The gap between them has been "bridged" with the trace on the board and they now share the same signal path.
Connection, terminal and output all describe the same thing.
Mono=ONE.
A monophonic amplifier can have multiple output connections. Nobody is saying connection means channel in this argument. Nobody ever has except you. YOU are grouping the two words together to mean the same thing (Channel - Output). That is on you that you refuse to listen even after being told several times that in this argument OUTPUT IS A CONNECTION A TERMINAL on the amplifier.
Here, use these pics to show us where YOU would make them one terminal. Same amp in both pics. Come on Rob, don't get quiet now.
Are you asking me to show you where they are connected to the trace on the circuit board?
You'll need to flip the amp over and remove the bottom cover, then I can probably identify the through-hole and solder point, plus show you the copper trace. The copper trace might be tough if they sealed or otherwise made it impossible to see where the copper was etched away to make the board.
Can you provide that picture?
No, I can't provide that picture. It is not needed. The point is, the trace is the 3rd THING, the bridge that connects those two terminals. I rest my case.
Slo_Ride
Regulator
Slo_Ride
ATLANTA
Buck
BP1Fanatic
    Jul 1, 2026
BP1Fanatic
    Jul 1, 2026
