Winners only.
It's your argument Rob. Are you mad at me because I don't care to participate in it??
You’re here. Participating.
Define innervated to the laymen Rob. Break it down so non medical trained persons can understand what it means.
Innervated means nerves have been supplied to the bone. In even simpler terms: Nerves are in.
I am not an OTR driver so again, no plausible premise. No Irony.
Oh? So what makes you a “professional driver”?
You are struggling Rob.
Not in the least. I have plenty of examples where your actions are ironic.
Like you thinking a mono amp has multiple outputs, when no mono amplifier circuit exists that has multiple outputs.
The ironic part is you literally ignoring the meaning of the word mono, and insisting it means “multiple”.
I am not here.
To does not mean in.
I am paid to drive a rather large truck for a company.
You don't actually.
Even if a mono amp had just the positive and negative terminals, each terminal is an output. More than one is multiple. Argue that you jackasss.
Semantics.
I am not here.
Then it must be your babysitter typing for you.
“The word innervate sounds like what it is — it means to “put the nerves into” something.”
Are you familiar with “into”. It also uses the word “in”. For a reason.
And it’s fecking hilarious you are still arguing that bones are not innervated.
Without a CDL? Then you’re an employee. Not a “professional driver”.
You don't actually.
Oh, there are plenty.
Like the time you argued that video is not proof the insurrection happened, but then wanted to use video as your proof that Biden is a *********.
Ironic.
That’s not how an amp circuit works, simpleton. Here’s a circuit diagram of an amplifier. Do a markup on it and show us the multiple outputs.
Semantics.
“Semantics”. Like claiming mono is more than one?
I suppose you call that 1” dome speaker in your car a “subwoofer”. Just semantics, right?
Must be.
So it's "to" "in" and "into". Got it.
I am a professional driver. Be sad about it all you want.
Ironic.
Not Irony.
You have a positive output and a negative output. How are you seriously going to argue that it isn't more than one.
It's a mono channel with two outputs you ******* clown. A positive output or TERMINAL and a negative output or TERMINAL.
Must be.
Not Irony.
Incorrect. There is an output and an earth/ground. A ground is not an output.
You fail again. FFS, even the DIAGRAM only shows a single out.
Your comprehension is for shit.
There is no positive or negative output on an audio amp. It’s alternating current. There is a single supply output and a single return path.
That’s why the diagram shows a SINGLE “out”. All amplifier circuits have a single output.
It doesn’t get any more basic, yet you still don’t get it.
Apparently you don't know the meaning of the word professional 🤣🤣🤣
You poor lonely man.
Must be.
Not Irony.
The why during a discussion about monoblocks did you post this bullsh!t:
"What amp are you using? Car amps don't just have "double outputs" that are wired internally unless they are Pyramid crap type of equipment.
Multiple outputs means multiple channels. Leaving them unused means you have amplifier power not being used."
That's right...you just "randomly" posted it in between doing board level repairs on some kraco 2 knobs 🤭
So I have to drive to other offices as part of my job. I guess I’m a “professional driver” too.
Cool. I’ll add it to my resume.
The following is sarcasm at it finest....
I am so confused Rob. How does one take the DC voltage from a car battery or Alternator, feed it through the amplifier through switching mosfets and diodes creating positive AND negative rail voltage? So confused as to why you think the negative output terminal on a car audio amplifiers is a god damn earth ground. LOL
Slo_Ride
Regulator
Slo_Ride
ATLANTA
Buck
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
