Suitable Amp to push 2 Meso 6.5 subs
  • 5
Why not run the CT Sounds 1k? or even the 700? One my 2ks do great
As the title states. I have 2 4ohm CT Sounds Meso 6.5s. So 400/800 rms / max. I was thinking a Sundown Sfb1000, but In my ignorance, I fear 700+ watts to each speaker is to much. Any and all advice is appreciated.
Size
Head room doesnt hurt to have on tap if you tune properly and should generally run cooler. You could put the Taramps 3k on those prob and may not even have to place it past 8"Oclock position
I agree with above, You already have CT subs, may as well grab a CT amp to match..
I took advantage of their sale and bought more than planned. Lol.
Getting a good voltage reading does not mean good power transfer. You could read 13.8v out of a 24 AWG wire. Recheck your amplifier's ground and...
212
415
495
  • Locked
789
sizmtrz
Junior Member
sizmtrz
Detroit, MI
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
