Spring Grover
Hi, and thanks for reading. I been building systems in cars since the early 80's. Witnessed the start of Alpine. Fosgate, Crutchfield, Car Audio magazine. Submitted my `93 MR2 to CAM back in the day but was denied due to a firewall grommet technicality. Built some really awesome systems well before people were listening to anything more than the factory am/fm. Before subs were 6x9"s, Jensen triax's. If that weren't good enough, find an old Pioneer house speaker, delete the high end, throw in the trunk and you had a subwoofer. If the trunk was big enough, slide a beer cooler under one of the 6x9 which you didn't screw down..back seat bartender.
With all that behind me, I'm restoring a `66 Toyota FJ40, that I've owned for years. This is a tricky vehicle to install a system in, all steel, not much room. I'm installing in it, a Kenwood KAC M18S4BT amp, 4 channel x 50 with rca output to 4 KEPF HTS 7001 home (yes home, 8 ohm) satellite speakers on all 4 corners. Due to size constraints, these little guys are perfect and sound amazing. With the rca out's, I'll also run an old Alpine 3503 to power 2 planar tweets mounted in the roll cage bar pad, reflecting off the windshield, through an attenuator to control the level. Both amps mounted within the the heater duct to conceal, not to mention, no where to put them. Also from the rca out, going to a reoil SL1708 sub I managed to squeek under the seat. Whole system very discreet but should sound amazing in an open air platform (think Jeep).
Getting to my question here, FINALLY. Tech I'm not current on. The Kenwood bt amp has a wired remote that I mounted on the stick shifter. I'm looking for a way to wirelessly control the Kenwood Bluetooth amp, from a wireless controller I can mount on the stick, from my phone that mounts on the dash? Bluetooth from phone to controller to amp, wirelessly. Is this possible? Not sure how this forum works, but I'm starting here. Looking for solutions, hoping someone can send me in the right direction or say definitively yes or no, again this tech, out of my realm. If you need assistance on configuring an old school power 650, I'm your guy. Wireless Bluetooth, not so much. My current system, Not so fancy double din Kenwood cd/dvd head unit 50 x 4 powering four 4x6" Quart's in my 2000 f250. Subs, 3 x 10 JL 10w6 (made in USA), first gen Punch 75, rattle's the wiper blades.
Thanks for reading, was fun to write actually. Look forward to hearing from you.
Best
M
Best
M
