resilent sounds Gold 10 inch information is very confusing to me.
Memme
34
Sweden
Hey i live in sweden and i want to but some subwoofers from resilent sounds. But i cant understand what they mean it says. 1.25-1.75ft tuned 35Hertz with 12-16 inch of port area per cubic foot. But the thing is that it says the same thing on every subwoofer so it isnt easy to know wich box volume i should have. It doesnt say the mounting depth or displacement. i dont understand either wwhat they mean with port size 12-16 inch of port area per cubic foot. If someone could help me or if someone have these subs that know this information i would really appreciate it! :)
Edit:
What i have understood is that i should have 50L=1.75ft3 but since i have 2 i guess 100L=3.5ft3. but i still cant understand port area. it says the same thing on every sub.
It means the sub works within those box sizes. Plus it also works good with 12 to 16 square inches of port area regardless of what suggested box size you use. I figure port length is determined using the chosen parameters above plus the 35 hz. This with the help of a box builder program.
Come to think of it, this sub sounds like a great candidate for pre-built boxes. Not too finicky.
Seems pretty straight forward. I would say 1.25 cu ft sealed enclosure would be good for the space conscious, but if you can go 1.75cu ft, the the port size is given. Use a speaker box builder software like WINISD or the like to determine your port length and size. It provides you the option to chose either round or rectangle port mouth.
I was able to log in fine, using Chrome if that helps. I don't know anything about the product at all, just found the info and shared the love. :)
565
Brother in law has some of their 8’s and they are little beasts. Typical cookie cutter product that performs as it should.
Off the shelf design, nothing special and will sound like a bull horn. The best pro audio drivers I’ve heard are the crossfire XTpro6’s. The best...
The formula is Square Root of your target Wattage Multiplied by Ohms. 50Wx4Ohms=200. Square root of 200 is 14.14. So 15v AC is your target.
Memme
Memme
Sweden
DRBOOM
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
