Dual battery question
  • 5
Mr.D
24
Miami
I have an AGM battery under the hood and an XSpower D3400 in the trunk, I am running a stock alternator on my Infiniti q50 which gives 150A. Should I be charging my batterys at night? It's a 2000w RMS system. Thanks in advance.
I have the same car.
I'm running a DD M1d (1750) and a DD C5 (400) with the stock alt and an AGM under the hood and I'm not getting any clipping
What amp and subs are you running
2 kicker L7 12s with a rockville DBComp5 it has a clip light and it would go off with barely any bass. Now that I upgraded the batteries it goes way louder before the clip light comes on. Still feel like it should go louder without clipping.
Check your overall system voltage. You may want to charge your batteries if your batteries start resting below a certain voltage. Alternators won't deep charge a battery like a battery charger will, from my experience. Just check on it. I had my system and used to have to charge my batteries from giving many demos during the work day.
I recommend you get something like a stinger volt meter, learn where your normal system voltages are while you're playing on the road, or sitting still, vehicle on/off. Just learn the vehicle and you'll know when your batteries might need some juice.
This is the answer I was looking for. Thank you so much!
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
758
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
779
Recoil 2500.1 $179 2500 x 1 @ 1 ohm. Make sure subs are the dual 4 ohm version. If you don't want that much power, get the Recoil red1200.1 for 1...
877
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
Mr.D
Mr.D
Miami
Mr.D
SlugButter
    May 4, 2024
slater
    May 2, 2024
