If this amp will work on the speakers im planning to get
7saiin
24
Bahrain
Im planning to get 4 jbl gto629 speakers for my car and i was wondering if my amp sony 600watt 4/3 channel xm-zr604 would work perfeclty with the four speakers with no damage even at high volumes? Concidering the speakers are 3ohms and the amp is 4ohm
Id appreciate the help
I think you’ll be alright. The amp is 2-ohm stable so it’ll run 3 just fine. Somewhere around 60-65 watts RMS x 4. The JBLs are rated at 60 so you should be pretty perfect I’d think.
The amp says it has 600watts and total of 4 of the jbl gto629 speakers is 720watts 180watts each is it fine?
286
It also lowers the amps efficiency and raises the current draw.
404
536
It may be that they act like this because they are underpowered and the push to play them louder is causing the amp to clip the signal, which will...
Tons of options in that budget, including the cost of installation,
727
7saiin
7saiin
Bahrain
Marve_Lous
    May 12, 2024
    May 11, 2024
