• 7
Loud(ish)_Geo
Hello, I'm new to the forum and figure that a build thread was probably the best place to start
I own a 93 Geo Storm that's currently running 900watts rms and 3600w max total
I have full Polk Audio DB+ series door speakers (because they were most powerful 4ohm coaxes I could find)
With the factory 6.5" size in the front and the rears are cutout from 4" to 5.25"
These are all run by a pioneer GM-D8704 @100w RMS per channel
In terms of a subwoofer I currently have a Rockford Fosgate P3D4-10 in a prefab box powered by a pioneer GM-D9701 @500w RMS
For power all I have is a 2.5 farad capacitor which will likely be the next thing I'll upgrade because I'm still getting voltage drops and headlight dimming at full volume
First upgrade the power & ground wire. Looks like you running something like 10 gauge. I would upgrade it to 4 gauge at least, do 4 gauge all the way back to a fuse distribution block on the power and a standard distribution block on the ground then 4 gauge to both amplifiers and you will be much better off. Then do a Big 3 upgrade and a bigger alternator.
I currently have a 4gauge power and ground for the cap only. I'll have to see about upgrading the wire to the amps to the same because they are pretty dinky at the moment. Thank you for the advice
Try going into your settings and look for system sounds. You may be able to adjust it there. Or, you can go into your phone settings, look for...
LMAO.yep,this setup going on over 9 years.appreciate the inspirational quote although i dont take part in water boy memes.
863
Welcome to the forum. I hope things go well for you. We like good products made in the USA. I'm cool with paying more to get that.
No rc bug yet? I got bit bad and left audio for years doin rc again.
22
4K
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
Loud(ish)_Geo
Loud(ish)_Geo
Pennsylvania
Louisiana_CRX
slater
    May 2, 2024
slater
    May 2, 2024
