How Loud is 5000 watts RMS
Put your purse down and quit being so sensitive.
To get to the vague question I have seen people with 5k struggle to do a 145 and I have seen people with 5k do a 160.
Too many factors.
My two Sundown SA-8s on a 1200 could be heard from a block away if I wanted to be annoying.
Inside the building with 3 walls of separation, you'd hear it in the walls from a block away. Then you'd hear the notes when it was on the road in front ~100ft. Outside the building you'd hear it about a block and a half away. He kept his windows down or it wouldn't be quite as loud. I see his car around a lot, just only hear it in certain areas so I've got nothing against him. Nothing wrong with a bucket list, but framing it as noise radius is gonna raise some eyebrows lol. 5kw and custom built box you'll need a permit with the windows open. I reckon his is a little more powerful or the same as the one jt4x4 described. Yukons and Escalades make pretty good installs when money's no limit.
Jeez and you said this Yukon didn't have 5k in it and can be heard like from a block away?
This question might be stupid but I have a Cadillac escalade that I'm shoving 5000 watts in. The loudest system I ever had was 1500 watts RMS. I really dont know what to expect. I want that kind of Bass that can be heard from atleast a block away. My electrical is 100%. 2/0 welding cable, 3 xs power batteries, 2 mechman 370 alternators and SMD fuse holders and fuses. Any response is welcome even if you wanna be smart and sarcastic. Thanks in advance
Is this for competitions? Just concerned that you will have a hearing problem later in life; if you listen to music that loud for extended periods. Be careful.
With the right enclosure and vehicle it doesn't take a ton. Obviously he's invested in a better alt and at least one other battery to get where he's at, but mostly he's just tuned very low, objects in the room resonated, and his windows were down. You can't see a box from the rear windows either, so he may even be able to seat 4-5 people. It's not a Yukon XL btw, those can seat a small army.
Deaf Bonce Apocalypse 15s and a Orion HCCA 5k
Just because you have a 5k doesn't mean you're getting 5k after all the variables involved. If you want a true 5k rms. then you should start with about 8k. Regardless, just wanting to be heard from blocks away, shouldn't be your #1 goal with your system. I've got HOA letters for vibrating my neighbors furniture. That wasn't my goal. My goal was good all-around system. Not bass heavy or a treble Rebel.
True, I want to keep the noise in the car, those people ain't paying for the gas my alternator's using up.
Sound deaden the car and have the right enclosure and you should be fine. Don't be a rattle trap either. Nothing worse than hearing a car that sounds like it's falling apart.
Yeah that's one thing I can say for the Yukon that drives by shaking up the whole main street.. He doesn't have a single audible rattle. No license plate slapping or tin-canning on the frame. It just sounds like bass.
Try going into your settings and look for system sounds. You may be able to adjust it there. Or, you can go into your phone settings, look for...
LMAO.yep,this setup going on over 9 years.appreciate the inspirational quote although i dont take part in water boy memes.
959
Welcome to the forum. I hope things go well for you. We like good products made in the USA. I'm cool with paying more to get that.
No rc bug yet? I got bit bad and left audio for years doin rc again.
22
5K
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
Mrjones203
Mrjones203
All over
JohnKuthe
    May 18, 2024
    May 18, 2024
