Other diagnosis methods for a head unit
Lasherž
Just curious before I give a friend of a friend some bad news about their head unit.
It's a Dual head unit that's dual dimm (Model XDVD269BT). I took it home so it's not hooked up to a car, but they said a previous technician said it wasn't getting ignition. I soldered and shrinkwrapped all of the connections and then hooked it up to a variable DC power supply. + to bat+ and ignition and - to ground. This unit doesn't have any fancy ECU turn on like some volkswagens. When it powers up (12.8v) it goes from .015A to .4A and makes a sound presumably to check if there's a disk inside, but no display. The Bluetooth is working, but no display no matter what I do. I can try to get it to play music, but there's no point if there's no display. What do you installers do when you don't get a display but the unit is pulling operating voltage and current? Is there another wire I need to short to positive like illumination?
Feel like it's pretty obvious but I'd like to be sure before I agree with the other technician who left it in bad shape and tell them they've wasted a week chasing the issue.
I put a disc in and it came to life... What the hell type of stupid problem is that lol. Junky ass Dual receiver.
I believe it happened because the eject button is able to go so far down that it can lodge under the bezel and when it turns on with that button down it confuses the chinesium alloy parts in there. Once that happens you have to feed it a disk or it'll just keep waiting on one forever.. My hypothesis anyways, but it works now.
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
447
598
I have a 06 grand Marquis. Looking at either Kenwood or Sony Apple play. Is it worth have a floating monitor? Pros and cons?
847
Lasherž
Lasherž
United States
    Apr 27, 2024
    Apr 27, 2024
