RCA Selection. Any Suggestions?
Bobbytwonames
Trigger Man!
Leaning towards Stinger 8000. I have one 4 channel amp and one mono amp. The longest run is only 12 feet. So, just a combo of 12 and 3 foot cables. I will be running the Dayton DSP408 with a front, rear, and sub set-up. All separate drivers. I need to get the RCA's now. Suggestions?
Loaded question. I have a whole tub full of Stinger RCAs because a friend owns a shop that carries them. I prefer my Knukonceptz Krystal and Karma cables myself.
So, does this order look right? I'm using that Dayton DSP408 and it looks like it only has two inputs. Does that mean I can delete the two channel 13' cable for the subwoofer? Only needing a subwoofer rca from the dsp to the amp.
The length of the rca depends on where you mount the dsp. Always have a little bit more length than you need, its annoying not having enough.
Itll be 5 pairs of rcas total to buy, two short runs 3 longer runs. Monoprice has good quality cables for cheap as well.
I was going to get knu concepts. RCA's. I'm about to hit proceed to checkout on these. I'm thinking that I can delete the 13' 2 channel run from the deck since the DSP is only 4 input. I will be running a front, rear, and sub set'up (all separate drivers). See attached. Thanks for helping me through my confusion. Knuconcepts seems pretty highly rated and well constructed.
Bobbytwonames
Trigger Man!
Bobbytwonames
Vegas
Bobbytwonames
vegang
    Jul 1, 2026
vegang
    Jul 1, 2026
