What's ideal box size and tuning on the cvrs?
Are you going for peak spl or daily with a wide frequency range? What kind of music do you listen to and what vehicle?
What is an HDS1222? You mean HDS2 12"?
This would be installed in a '98 Mercury Mountaineer. Daily driver in winter. I mostly listen to rock/metal. Space is not issue really.
I was thinking of the XFL 1222. This is an HDS3 12" 2ohm dvc.
3.6-4.0cf with a 6 inch aeroport tuned to 36-42hz
4@40 looks like the sweet spot
Thanks. I typically just use a slot port. Assuming that's okay. Not sure if you were simulating that or just glanced at kicker's specs.
