Taramps HD3000 for $179
They are a 1/3 of the size of a Wolfram 2400.
They do slightly more power.
Full range amp so can be ran on subs, mids, horns, and tweeters if wanted.
They are actually in stock.
$50 cheaper.
Both good amps though.
They are a 1/3 of the size of a Wolfram 2400. They do slightly more power.  Full range amp so can be ran on subs, mids, horns, and tweeters if wanted.   They are actually in stock. lol
Ok. Also seeing the MD 3000 is like 40 dollars more, which would you choose? The HD3000 or MD3000 for a subwoofer?
I read some more info too.  Seems the baseline (median) for the HD series was modeled at 1khz to rate power output.  The MD series reached the same goal modeled at 60hz.  Probably why they recommend the MD series more over the HD for subwoofer application.
Off topic here... but I seriously don't know what to make of this...
Brazilians... omg
Shipped from Amazon so its legit. Used it once before for something else and no issues.
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
Team Lethal Pressure
Central FL
MattinMO
    May 20, 2024
    May 20, 2024
