what amp
Pretty much i just replaced my terrible 10w sanyo 4 inch paper speakers in my suzuki jimny, with some 35watt rms 4inch ones just the front x2 speakers, i picked up on special my headunit is still stock but will.be replacing that. Im not looking to spend alot of money i just want to improve what i have, ill buy a new headunit and was then thinking of amping the new speakers i have if its worth it. Im not looking for a superloud audio system. not looking at spending anymore than say 200$ on a amp just woundering what wattage amp would be best
for what you're trying to do I'd consider something with a built in dsp. pioneer deq-s100OA or kicker key 180.  both have built in dsp. I'm not familiar with a Suzuki Jimny surely there's more than just 2 4" speakers?
Yeh only x2 4inch speakers in the front theres wires in the back for another set but theres no speakers there the jimny is only a small 2 door 4x4, how does the pioneer one work? Can i attach a subwoofer?   And do i need to replace the headunit? Or does it just work like an amplifier the pioneer one you mentioned
Yeah you can use your factory radio. No it will not power a subwoofer. It's 4 channel but not bridgable. It's a piece you can build off of however.It has 3 sets of 4 volt outputs. Would be pretty easy to add a sub amp. Idk I'm guessing pioneer has a lot of information on it on their website. I've not used 1 just aware it's on the market and the advantages of having a dsp..
I agree with others, just buy the OFC. My last wiring was oversized CCA, and while it still works, and looked okay when I peeled the heat shrink...
86
The audio frog gb subs do have good output but aren't spl monsters I'd compare them to the w6 output wise while I believe they sound slightly...
99
127
114
Thanks for all the advice. Ultimately, I was able to get them to honor the warranty contract. It took a lot of back and forth and I received...
248
paz
paz
fithwheel
