the pirate bay
Yeah, the Pirate Bay won't go away... it will just change locations. ;)
i REALLY miss demonoid
I have no use for it anymore.  I just found out about Radarr, and since I already use Sonarr for all of my television, it was a no brainer to set up and now I have unlimited movies too.  WEWT.
i run a VPN specifically for downloading stuff. nothing more satisfying than making your ISP think youre streaming stuff from Venezuela whilst obtaining stuffs
As said TPB always just loses their domain. The servers stay up and they just change their domain. It seems to be happening more often now, you can always use the tor network and it doesn't change afaik
If I can't find something on TPB, rutracker is by far the largest tracker right now. There's more bullshit with viruses but you can usually avoid that
I'd love to get an invite to waffles.fm (waffles.ch) if someone has an account. I seed at 1gbps so... it'd look good on you if I can find something to seed that isn't flooded with seeders
it happens with torrent hosts, for sure.
ill check that tracker out too, sounds like a good way to get some results! Thanks!!
ive not been made aware of waffles.fm yet, is it like demonoid?
waffles is a private tracker with the highest quality music library available afaik. Every song has 6 different versions of quality including FLAC and pure lossless. All the torrents are seeded heavily so EVERYTHING is available and not dead. It requires an invite and you must maintain a high seed/leech ratio or they'll disable your account
what.cd used to be a better middleground because you can get in easier but it got taken down
youdoofus
Skibidi
youdoofus
planet earth
RobGMN
