Sundown vs. Addictive Audio
Addictive is local to me, about 30 min away. So a ton of ppl run it. Its junk. Bad soft parts, lots of amp failures. Not a single impressive build from any of their local sponsees
Yea they should just stop with ADdictive audio and start new with vital power, heard good things about those amps and about to try two of them in acouple days hopefully.
Well its a proven board. They didnt do anything but a rebadge. But the locals have good luck with it. Id never run it, but i have no qualms suggesting it.
my buddy bought two the fix 500.2 and had immediate issues and defects with both of them. RMA'd and still had issues while his ct sounds, cadence and some other cheap amps never had issues.
Can't go wrong with sundown, for amps and alts i would go with Singer and Ampere Audio. Look into FU audio and SSA for subs as well. A pair of 1250's from FU or a pair odlf X'CONs. Should do well, I would stay far away from AA right now,I had bad luck with AA and the cs was **** just a fyi...this is a drunk post brought to you by jameson whiskey
My concern is I listen to such a vast range of music I want EVERYTHING to sound good, because well, who wouldn't?
You might be overthinking the whole sounding good part when you are about to throw 4.5kw at them. There is this point where Sq kinda gets tossed out the window because you are covering your ears anyway and it feels like your head is in a vice. And then you say "God ****, this sounds great, I can really distinguish the tonality of the is 155db 40hz bass line that is making my vision blur."
bigmak927
bigmak927
Detroit, MI
vegang
    Jul 1, 2026
vegang
    Jul 1, 2026
