SQL Setup - Dual 12" - 1000W ???
Ruffy
Death to the salad eaters
I'm thinking about two Diamond D6's. Unsure about 4ohm dvc or 2ohm dvc. I'd probably go with the 2ohms that way I can run the amp at 1ohm and not have to pay as much for a 1000w @ 2ohm+ amp. I am worried about heat though so I'm still undecided on the amp. I was looking into a ED nine.1 but have reconsidered. Looking to spend under $300 for the amp.
Do the D6's handle that kindof power safely?
What other subs are out there for the same price-range of $300-400 for two 12" subwoofers?
Also when you pump 1000w into dual 12"s. Do they essentially both get the 1KW RMS or is it split in half between the two?
Finally How would a Alpine Type-X Vs the D6 compare? The Type-X is more around the D9 price range.
the RMS wattage is split between the two subs when you do like your doing.. to get 1000RMS to each sub you would need a true 2000rms amp
Thats what I figured. So I guess i'll be running them around 500 to 600w rms each. Which is what their rated at. Although I hear they're underrated so dont know what to do that with that.
2 4ohm DVC subs wire to a final impedance of 1 ohm...2 2ohm DVC subs wire to 2 or .5...SO depending on sub choice or going to need either 1000W@1ohm or 1000W@2ohms...unless of course your running one amp per sub then ignore that... I would take the D9 over the Type-X though...but thats just personal preference
yeah 1kW at 1ohm or 1kW at 2ohm is what i'll be looking for. Depends on how price is and how many pennies I end up saving.
Ok I'm pretty much decided on the Diamond Audio D6.
Anyone know of a good amp for them? Looking for 1200W+ @ 1ohms or 2Ohms stable.
The 4ohm DVC's are cheaper right now than the 2ohm ones. So I'm leaning towards them.
my concept cc-d1200 is a good match //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
you still selling the infinity reference? I might get it for giggles at that price. Only problem i see with it is I can't really power it. My current amp is only stable at 4ohms bridged //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Well I ended up buying 2 Diamond Audio D6D4's off Sonicelectronix.
I'm thinking about the Hifonics BX1605D. Amp for them. Going nuts looking into all the 1200W RMS amps @ 1ohm out there. Any other suggestions? The Hifonics is funny. On other sites its rated as 1200w @ 1ohm. On sonic it's rated 1600w @ 1ohm
Still unknown if I'll get a box built locally. Build it myself. Or Buy a premade($39 + 35 shipping at Sonic at 1.21Cu)
Waiting till my Credit cards payed off before I order the amp.
Get a custom ported box... low tuned preferably... you'll be glad you did... unless you have an idiot build it.
The enclosure is THE MOST IMPORTANT PART...
I believe i'd prefer a sealed box instead. For asthetics, sound, price, and space reasons.
Hmmm, only part I can agree with there is the space issue //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif. As for the amp, fok the hifonics //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif. Its overated, which is why you prolly see some sites list it at 1200watts. I'll sell ya a kx 1200, if interested. If not, she'll be on ebay tomorrow //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif.
28
I'm putting 2 under my rear seats with 2 passive radiators. Only a 3kw amp. Only reason I'm selling my adire subs before even trying them. Granted...
20
Those pair of 12s with the right enclosure and tuned as well as powered properly should perform much better than the single 15, provided you have...
Great bang for the Buck/ Have (2)2ks and a 150.4. great amps for the Coin Thus far.A little head room doesnt usually hurt...
Ruffy
Ruffy
Las Vegas, NV
Ruffy
    May 12, 2024
Brendon Jenness
    May 11, 2024
