New amp not big enough for Kicker L7?
Got it Uhrin?
With that sub and amp you have now, you must wire it as a 4 ohm load because your amp requires either a 4 ohm load or a 2 ohm load, and your sub can not be wired to be a 2 ohm load. And, as you seem to have found out, all this means is that your amp is only gonna put out 330W in that 4 ohm situation.
You could also do this; Buy a 2nd of the exact same sub, wire them to a 2 ohm load. Then your amp will put out 330 watts into each of the two subs.
lulz maybe u blew the sub....did u ever get a weird smell while bumping?
lol, ****, sub is blown... just rewired down to 4ohm and the amp still turns off, but it stays on long enough for me to hear that it's blown. //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
Black widows sound amazing done right for sure...I remember seeing a quite a few cool looking and good sounding loudspeaker setups when I was in...
16
249
  • Locked
521
Amp
422
Uhrin
The Cake is a LIE!!!!!
Uhrin
Spokane, WA
Uhrin
    May 24, 2024
