you mean .5 or 2 ohms together. That Ample Audio is also a monoblock, so they are wired to .5. Hopefully your "shop" didnt crank the gains either, cause itll be dead soon if they did.2 2ohm dvc subs.......if it's a 2 channel amp and you run 1 sub to each channel then each channel is getting 1 ohm or 2 ohm if you use only one voice coil......if it's a 1 channel amp then you can run it to .5ohm or 4ohm if you wire the voice coils pos to neg and then one pos and the other neg to the amp......there's no 1ohm result from 2 2ohm dvc subs running to 1 channel.....
