exactly, "THEY" are on "A" ample audio 1100, that means 2 subs are on 1 amp, which means they "ARE" wired together //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gifi understand but theya re on a ample audio 1100dx right now...
could be 2 channels, point is, the subs can either be 2 ohms or .5 ohms when wired together. When wired seperate each sub with be wired to either 1 ohm or 4 ohms. Either way, learn to read people's posts.exactly, "THEY" are on "A" ample audio 1100, that means 2 subs are on 1 amp, which means they "ARE" wired together //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
no you cant! please stop for one minute. your two woofers if wired to a mono amp can only be wired to .5ohm or 2ohm. that will never change it is constant. now if you have a 2 channel amp you could wire each for a 1 ohm load like that. this is how ohm's work you cant change it lolu can wire them on 2 ohms or 4 ohms or 1ohm
