Multiple Capacitors
  • 6
Huh ?? You confused me //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Multiple caps need to be wired in parallel
+ to +
- to -
Run from one of the caps + to the amp. Grounds are grounded. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If you wire capacitors in series, it reduces the total amount of capacitance as a result of increasing the distance between the plates. Wiring in parallel increases the total capacitance.
To add the tv, I got a second deep cycle battery, ran thick cable from my starter battery to the deep cycle battery(or you can run to a dc to dc...
The amps are not fused themselves. I am considering using smaller gauge wire for the 200 and 300 watt amps (I believe they only recommend 12 awg...
Ok ill just do the two ohm for now .i have really good electrical .ill prolly just go ahead and buy a bass 8 or 12 k for now until i can get a...
I have a 2012 Ford F150 Platinum Crew Cab. I was saying that since my secondary battery would be grounded to the frame could I not ground my amps...
75MonteCarlo
pwned by the R
75MonteCarlo
Saskatchewan, Canada
stones
