Main Input Gain (it Sets The Maximum Volume Level
Achievable By The Front Controls)
* 7-band Graphic Equalizer
* 6-channel RCA Outputs
* 3 Input Sources
Adjustable Master Volume Level Control
* Adjustable Subwoofer Level Control
(front/rear/subwoofer)
* Gold Plated RCAs
* Easy Snap On Connector
* Bypass Position Notches On All 7-bands
* Blue Background LEDs
* Push IN/OUT for main or AUX
* Front Mounted Easy Access iPod/AUX Input
Specifications
Operating Voltage: 10.5---16VDC
Idle: 170 mA
Recommended fuse size: 1 Ampere
Input sources:
2 stereo RCA sources, 1 Phono source
Input sensitivity:
Adjustable from 100mVrms up to 14 Vrms
Input impedance:
Variable from 3.8 Kohm up to 10.2 Kohm
Output Impedance:
Sub channel: 510 Ohm
Front & Rear channels: 2.2 Kohm
Output Level:
Subwoofer channel: 11 Vrms@0.1% THD
Front/Rear channels: 7 Vrms@0.1% THD
T H D @ 3 Volts output: 0.003%
Frequency response: 15 - 34000Hz @ -3dB
Subwoofer frequency control range:
60 to 160Hz (@ -3db, 18dB/oct.)
Subwoofer upper cut off frequency: 160Hz
Channel separations: 68dB
Signal to noise ratio: 96dB
Center frequencies (in Hz):
45, 120, 275, 700, 2000, 5000, 14000
Control Range:
18dB (12 O'clock is the Bypass position)
75 shipped bnib full 1 yr warranty its an earthquake brand model# EQ-7000PXI
pm or email if interested.
