Distortion Question
DOOM_NX
2 x 95W RMS 4Ohm speakers
1 x 60W RMS per channel 4Ohm amplifier (total 4 channels)
To set gains with a DMM, I used the following formula: sqrt(60W * 4Ohm)= 15.49V
So amplifier is giving 60W, speaker can take up to 95W. Yet when playing 1kHz sine wave at 0dB it sounds distorted. What's wrong? //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
could be all 3...
Speaker: Hertz DCX690
Amp: Hertz EP4
now, cables are Audison Connection, but I don't know exact specs... should be the right though...
Those speakers are mounted to the rear deck... like the pic below:
So, Immacomputer, you suggest I set speakers by ear, no DMM, no tones? I'm afraid I don't think I have a trained ear to do that and they might clip as hell... But for subwoofer, you do suggest a DMM, right? Cause there is no way I can hear distortion...
To make matters worse, I think the right speaker is distorting and the left isn't... help?
It could be the HU sending out a distorted signal, it could be that the gains on the amp are too high, or the speakers may not be able to handle that much power without distorting..
either way you need to turn something down..
You shouldn't be setting your gains with a DMM for speakers. Set them by ear with music playing.
^^unless of course you need to limit the amount of power and not give them everything your amp can
mids/highs distortion/clipping is VERY audible, it'll sound like a stock system when you just crank the volume all the way up
So we got a pair of speakers rated 95W, but not even being able to manage 60W... great...
HU volume is at 46/62 and gains set with DMM as I said...
EDIT: I'd like to emphasize that I don't hear any distortion when playing music, just the 1kHz sine wave at 0dB...
The mounting baffle... I don't know if it's considered solid... It's just the original baffle, just cut out to mount the speakers...
Car is a Nissan Micra K11, '98 model by the way...
Your eyes and ears will keep you from reaching that point safer than a DMM will. Setting gains with a DMM for mids/highs will almost always limit your max potential clean output while listening to music.
Even when it comes to subs, I use my eyes ears and nose to set gains as I don't trust DMMs nor will the load be as simple as the nominal resistance and it won't be purely resistive either. It's a good way to be safe for subs if your judgment is bad.
So nobody uses the 1kHz sine wave at 0dB some people are talking about? It's easy to tell when speakers start to distort that way... I'm almost sure I won't understand when MUSIC starts clipping.
U have to ignore that idiot !...thats the next thing i would do is check wires.i would run new beings how the wiring is old.
Hey guys, anyone with a DD-1 or other distortion detector in the south florida area ? Thnks
The amplifier will only amplify the waveform that you put into it. I think you have missed or are misinterpreting something here.
I don't think so, it is the standard radio/speaker combo that comes from factory, but I will do some research to make sure there isn't one hidden...
956
DOOM_NX
DOOM_NX
Kozani, Greece
DOOM_NX
    May 31, 2024
    May 24, 2024
