DC lvl 3 problem
Yea, I know what the bass boost on the headunit. Its got like 2 settings right?
Thats still not the place I'm talking about, In the main menu where you can turn the beep on your headunit off, set your clock, and all those other things. The main menu, you can only access it when your headunit is in standby mode.
How do i get into stadnby mode, just got the hu, and ya, the bass boost has 2 settings on the hu like l2 or l1 and off
Theres a button to switch from the radio to a cd, I think it might say mode on it or something, But just push it until standby comes up. Bottom right of the cd player maybe?
when i go into standby i can do 3 things things, sb oem sb 4/5 and sb 6x9
Thats pushing in your volume knob right? If so thats not the main menu. Theres another button you have to hold down for about 3 seconds then it goes into the menu. It could be the same button for the bass boost.
ok brb agian lol
ok, i got into that menu what am i looking for nothing about sub in there
Just came out to my jeep, in that menu when you go down a few options there should be one that says swpre r. if you go over it will change to swpre sw.
That will give you the option now to change your sub lvl.
yep, got it so can control sub, but it still bottoms out =(
If the sub is bottoming out you're simply giving it too much power for the box it's in, or you're playing too far below tuning and it's unloading on you. The 15" lvl3 is a better sealed box sub anyways. High qts, high vas, low fs = good sealed sub, from my experience. Put something like that in a normal sized ported box and you'll get a sort of peaky response with a somewhat lacking low-end, in most cases.
Try going back on the gains on your amp and turning the sub lvl up a little. There could be a few things causing the sub to bottom out. Like to much power with to big of a box, or just loose suspension.
not understanding what your trying to say, go more or less with gain
but the kid i bought it from had it in same box, and on a hifonics 1000 watt, and it slammed, no clipping or bottoming out intill i put it in my truck?
Love the site, arguments over non-issues, not so much. ;)
13
86
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
https://www.caraudio.com/threads/all-bnib-focal-fdp-4-600-ds18-exl-p2500-1-sundown-audio-sfb-1000-4d-350x4-4ohms.614462/ :)
18
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
766
SpedBoy
SpedBoy
Brighton, Mi
littleharv93
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
