That doesn't matter. If I wanted to have a box like that, how would I do it? According to your logic, it's impossible.
external port //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The 12V calc isn't the issue at hand here, you're missing the point. The point is that the volume used in the calcs is net volume, after ALL displacements(this includes port displacement). the calculator doesnt know the port yet so if it doesnt how is still right? based on ur way of doing it?
You're using gross volume(or close to it since you subtracted sub displacement). how do you know the port volume without having 1 to account for in the calculator?
the calculator is set up to walk u thru it step by step in order of calculations and figuring box volume comes before figuring the port. so explain that ?
Even in the link you posted on roe as your "proof" had TommyK saying exactly what I'm saying. In case you missed it, I'll quote it for you.
"The easy way that I calculate up a NET enclosure is like this.
1) Figure out what net volume you want
2) Figure out the port size and length needed to tune it to what you want
3) Figure out the port displacement
4) Add 1&3 together
5) Design a box that has that much gross airspace"
