2x juggernaut 12s box???
  • 3
charleson99
hey everyone i have a 2000 monte carlo pace car and recently got 2 juggernaut 12s. i have a rf t30001bd that puts out over 4kw rms,because this is a pace car edition i want to design a box that will slide in and out of the trunk with out hurting too much
anyone have any ideas id like to hit high 140s?
ok im sorry i dont know what parameters is? if you could explain that would be great and about the biggest box i can slide in is around 16x20x36 and i would like it to be as loud as possible on a meter but still sound good on music, 2 different ports maybe?
Does that RF T3000 really put out 4800rms...? At what ohm load? //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
o ok here they are straight fom their website
JUGGERNAUT 12
Voice Coil (Ohms) 2 x 1.4
Fs (Hz.) 42
Vas (Liters) 27.6
Qts .45
SPL (1W/1M) 88db
Power (Wrms) 1500
Mounting Depth (inches) 7 1/4
Hole Diameter(inches) 11 3/16
Speaker Displacement (cu ft.) .35
that looks badass dude and i repect that you tune your box low,go low or go home
im goin to go ride around with a friend in his tiburon that does 155 legal with 2 rf t2 15s with a rf t4k to each!
be back in a bit
4800 RMS at 14.4 volts at 1 ohm its a 2004 model before the t40001s were out its badass
Yea, but in reality you'll be seeing over 1 ohm and wont be holding 14+ volts unless youve got a darn stout electrical setup in that monte...
Just saying, im starting your design here in a sec though //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
id rather not i like slot ports alot i had one of my premier spls in my monte, the box was 16x20x37 with a 70 square inch port tuned to 42 that did well
You stated you have an SIA 3500 right now. I would run it for now with the supply for the demand, until you decide you want more power and have...
366
Yeah if you want to be loud and don't mind losing the back seat start looking into building a wall. B pillar wall. Gives you lots of room for...
6
860
I don't know, maybe two 12's and two 15s on a IB wall maybe? Lol!
771
charleson99
charleson99
potsdam ny
charleson99
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
