Amp Problem... Please Help
2008ttcc
I have a Clarion DPX1851 850W amp wired into my truck... it worked flawlessly for over 8 months then yesterday my subs wouldnt come on.. so i checked out the amp and its blinking so I look up what it means and it says that it is sensing multiple shorts... I cannot figure it out... I checked my ground it seems like it is fine, yet when I unplug my fuse, and plug it back in it sparks which is telling me its the ground... is that correct?
Any insight? Thanks!
Get another amp and hook it up.. Quick install,just to see what happens.
Not much wisdome about the ground,take the bolt off,clean everything really good,spray it a lil bit with contact spray,screw it like a man (lol) and its set.
Check out if your + isnt ''naked''
Check for the rcaa's,and ofcourse the remote cable from the HU to the amp.
Check the speaker wire connections to your subs as well...if you have a box, both inside and outside the box...as you know, subs vibrate, A LOT, so something may have worked itself loose over time...between the subs banging and the truck vibrating over the road in the past 8 months, seems likely it may be a speaker wire issue.
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
658
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
698
If a sub's voicecoil fails, it will usually drop impedance causing too much current to go back to the amplifier. The amplifier then protects...
15
Have you checked the fuse block. With time, tight connections can loosen and cause failure. Refresh those contact points and test again. Remember...
132
2008ttcc
2008ttcc
Pickerington, Ohio
AlterEgo99
    May 18, 2024
    May 18, 2024
