Protect Pulsing, Help Please
Xero.Limit
I have a Memphis 16-MCD1000 Amp hooked up to one 12" Memphis M3 it's a dual voice coil and I have a Memphis Line Driver 16-VBF1.
With all that said everything was just working fine then I notice my subs cut out I pulled over to see what was going on and I find my Amp going in and out of protect everytime the bass hits and makes a clicking sound. I've searched the forums for a bit and have tried everything that was said to check. First I removed the Line Driver to eliminate that, the problem still occurred. I checked my power wire by the battery to make sure it was secure and not touching anything & also checked my ground. I live in Florida and it does get very hot during the summer and my amp was also hot so I pulled it inside so it can cool. I didn't notice anything wrong with the amp but I haven't opened it because I don't want to void the warranty if there even is still one.
Any advice would be much appreciated thanks in advance.
I opened up the amp and nothing was charred, burnt or smelled funny on the inside.
I tried hooking it back up after letting it sit and no luck. I disconnected the subs but kept the RCA's in and the protect light stopped could it be a problem with my sub?
If you disconnected the rcas and it stopped it might be an internal issue or a failing power supply or just a bad ground somewhere.Ill let someone else give you a little insight but that would be my first guess.
I kept the RCA's plugged in and disconnected the sub which is why I'm thinking that might be the issue but I don't know what to look for on the sub. I also already checked the ground it is still secured where I put it months ago.
As title. Once i get to about 4/5 max volume my JL HD600/4 amp goes into protection mode on 2 channels, powering my mids. The other 2 channels...
Not sure If I can Help you fix the issue without being present.. But the first thing i would do is remove all RCAs and All speaker wires from the...
maybe bad amps. I would purchase a decent amp off of Amazon. They usually arrive in 2 days if you have "Prime." If the problem persists, you can...
11
You don't understand understand brazilian amps and how finicky they can be about voltage...everything you just said nonsense
13
Xero.Limit
Xero.Limit
Citrus, FL
Xero.Limit
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
