99 ranger fitting and amp question
  • 5
69420potsmoker
Whats up, Just a quick question. Does anyone happen to know if I can fit cdt ef61's in a 99 ranger supercab front door? I know I need the adapter things and possibly spacers but will the 6.5 speaker fit in the 6X8 slot? I prefer not to cut things. Also If I buy a ampkit will it include everything I need to safely hook up my components to a 2 channel amp + head unit?
Thanks
1999 Ranger
Universal 6"x8" to 5-1/4" Bracket
Speaker adapter plates
http://www.crutchfield.com/S-jO4JSZxsc9K/cgi-bin/ProdView.asp?g=103200&I=142SA68
Im guessing thats your way of saying only 5 inch circle speakers can fit in there? Oh well, I will cut a hole in the door panel if I have to. I didnt want to do more work but it would be nice to actually see the speakers I buy. And WOW THATS AN EXPENSIVE LITTLE PIECE OF PLASTIC..............kiss my ass crutchfield.
Can anyone help me out with these last couple questions, Ill be ordering today and just want to make sure im getting everything I need to hook up my components with one of those amp kits.
Here is a template for converting 6x8 to 6.5
http://users.adelphia.net/~janeleslie03/Car_Audio_Resources/6x8_to_Six-and-a-Half_Template.doc
http://users.adelphia.net/~janelesli...f_Template.doc
Here is how mine turned out using that template using 1/2 in mdf.
old speakers
If you are getting a component set that has a higher excursion mid, I would recommend mounting the the bracket to the back side of the door panel. I have mine on the outside and the mid sometimes hits the back side of the trim panel. Even with all the extending plastic shaved off the panel.
wow thanks alot, its nice to see that can be done however that page isnt working for me and I seem to need to have been a previous member to enter. Im sure I can figure something out when I actually take the panel off I was just making sure it wasnt impossible.
Are you planning on reusing the power pack? If yes cut the wires at the top red arrow only. Connect your new radio harness to the translucent one...
Agree with hispl. TC sounds soft parts were few and far between years ago. If you’re wanting to run two TC based subs you may be better off...
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
841
That might depend on the head unit. Some can use a 5 amp fuse, some a 10amp, some a 15amp fuse (if / depending on how much it's powering the...
69420potsmoker
69420potsmoker
satans doorstep
troy_audi0
    May 31, 2024
    May 24, 2024
