Phase Test?
  • 4
wvufootball
Maryalnd
So my friend asked me to fine tune his amps and head unit for his car. He has 4 door speakers amped and a pair of rockford subs. His speakers are sounding like crap so the first thing i want to check is the phase. What is the easiest way to test it? do i just use a DMM on the speakerwire at the amp?
Wiring them all in phase only gives you a reference point to start from. If you want to actually try to tune the phase, the only thing you can do without the use of expensive processors is to try it with the wiring of the different drivers reversed. This can be a long process, and the more drivers you have the longer it could take. Take notes on what combinations you try so you don't try the same combo of relative phasing more than once.
just remember which colored wirees are pos and what are neg, hook them up accordingly......i have so many differant color wires its confusing sometimes...but mine are in phase luckily
What equipment are you using? It can be done physically (placement of sub), electrically (reversing wiring), electronically (DSP). If your amp has...
8
638
When in doubt, use an app called Signal Generator and play tones in the tens. The phase will be easier to distinguish.
5
987
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
271
But then you could just use the volume knob to rather than pay for earplugs.
749
wvufootball
wvufootball
Maryalnd
BassAddictJ
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
