Please verify
  • 2
tRiGgEr
San Diego, Ca
Ok I worked out my box dimensions. Please verify they are correct, so I can get started.
Resonant Engineering XXX 12" Sub.
Wood 0.75 or 3/4" MDF.
Sealed - 16w-13.5d-13.5h = 1.21 After displacement 1.02ft^3
Ported - 35.5w-15d-15h = 3.59 After displacement 2.49ft^3
Slot Port 13.5h-2.5w-36d = 0.91
Tuned to 30.47 hz
Can any one verify these dimensions for me to make sure I got them accurate.
Measure twice cut once as it goes.
Thank you. //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
Port length incorrect and that means dispalcement incorrect
That does not really help.
The dimmensions are external, 3/4" MDF.
The port displacement would be 13.5 x 36 x "3.25"
So when I double check it comes out right I just want some confirmation.
Oh and the dimmensions are of my box with the port already built in. There not my box dimmensions before the port. Think of it as me measuring an already built box.
I bet I'd get a reply If I said Audiobahn was better then RE...
using your port area 33.75 in^2 and box volume 2.49 ft^3 and tuning 30.47
your port is to long it should be 34.5192821 "
meaning your displacements are wrong if your port is incorect
lv= 34.5192821
Plv = 33.269281 if your doing a multiple port wall box
lv= 34.5192821
Perfect that is what I was looking for. Thanks your a lot of help.
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
190
855
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
858
tRiGgEr
tRiGgEr
San Diego, Ca
tRiGgEr
    Apr 26, 2024
    Apr 26, 2024
