More noise grounding to chassis than battery
  • 5
Danny Marz
14
Ok so I had a bad alternator whine when I grounded my amp thru the floor directly to the frame. Yes I hit the frame with sandpaper and a wire brush and had a clean metal ground. Then I tried grounding directly to the battery and the whine is basically gone. Does anybody know why this is??  I’m just keeping it grounded to the battery for now as it sounds 100x better
14 ram. Didn’t do the big 3. Not sure how large the factory grounds are. Seem pretty thick tho. I grounded the amp right to the same post on the negative terminal where the battery ground runs to the chassis
RCA's touching any metal?
They’re underneath the carpet so they’re touching the sheet metal from the floor. But the sheet metal is painted. That could be it. But I don’t see a possible way I could run the rcas without it coming into contact with metal at some point
It’s weird. Ever since I hooked it to the battery I only get a slight alt whine when I first start it up. After a minute or 2 of running it’s almost completely gone
If it were me, I'd leave it to the battery for the connection. Save yourself the hassle of trying to troubleshoot something can be frustrating and take days to figure it out.
Paint transfers electricity still... you need to shield them.
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Ill check it out. I was actually on the site last week. Thanks!
323
16
855
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
477
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
647
Danny Marz
Danny Marz
Jeffdachef
Brendon Jenness
    May 8, 2024
    May 8, 2024
