PM not working...getting error msg
Had the same issue with current private msgs and I kept getting a "corrupted cloud error". Had to restart a couple private messages I had going in order to get anything to go through.
Personally I wish the mods/admins would get tougher on some of the posts/threads again. Seems like everything has been lax, you report obvious spam threads/posts and it still just sits there.
Figured it out. For some reason my rca cables would work in everything but the new head unit. I quickly tried a spare set, and that fixed the problem.
There isn't much it can be. Pull the amp turn on wire out of the amp, and just run a wire from there and touch the distro block will activate...
Its lasted 19 years thus far. Could be something as simple as a wiring connection as stated. Nothing in electronics last forever. Its had a great...
The amp should still turn on regardless of your settings. Those settings will probably cause almost no power to come from the amp, but thats a...
Boomin_tahoe
Hurtin' feelings errrday.
Boomin_tahoe
WA
Firewalker
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
