Old Boston Pro 10.5lf sub
  • 2
JSMCO
19
CO
Guys, I have 1 of these old Boston Pro 10.5lfs.  The 2 ohm.  It's in a small-about 0.4 cu ft sealed custom fiberglass enclosure for my dodge ram under the rear driver's side seat.  It's been running off of one side of a Rockford Punch 500s so getting 250W, according to the amp specs.  I don't have the certificate to know for sure what the actual wattage is.  The manual on these just says: Recommended Amplifier Power: 50-1100 watts.  That's a pretty wide spread but it seems it should be able to handle a lot more than the 250W.  It doesn't list max power.  The site speakerboxlite site says the max power is 2200 watts.  So I don't really know what the best RMS power would be to run this most efficiently.
 Anyone here have any suggestions or real-life experience?  I bought a new Alpine PDR-M65 Amp, rated at 650 RMS into 2 ohms, the certificate says actual output is 796 watts into 2 ohms.  It seems that would do the trick pretty well, but before I take the plunge and switch out my amp, I thought I'd check here and see if anyone had some input.  Much Thanks.
throw the biggest amp on there and set the gains for XXX amounts of watts.  Just because you have thousands of watts doesnt mean you need to use all of it. just check dustcap or coil temperatures.
There is the 16pin connector in armrest of my old mercedes 2006 S350. Any possible way I can stream music from my phone wirelessly(Bluetooth) or...
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
The dirtiest hooker allive gotta smell better than fried Epoxy! (okay, that was a tad bit nasty, but funny nonetheless!)
JSMCO
JSMCO
CO
Jeffdachef
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
