Head unit turning volume down?
Its new generation 2014 Chevy impala, it does have the ANC but the shop that installed it took care of the ANC on it. So im thinkin im clipping. It's a 1200.6 amp and i did NOT do any electrical upgrades. I noticed my trunk dome light dims on very bass heavy songs. No headlights or cabin lights dimming. So maybe i need to upgrade electrical? It's a stock 150amp alternator.
"Took care of it" how? Did they wire the amp to the trunk light or something? Pics?
They just cut it? That's all you have to do to cancel the ANC on the bose centerpoint system at the amp. I should note that the shop that does my installs is a very reputable Arc Audio dealer in my area. I did not do any install myself. I suspect i may need to do a big 3 upgrade that would help my trunk light dimming. Im running 6x9s and 6.5s in series for my backfill since my sub is running bridged on 5&6. Perhaps not enough power to split on big bass drops?
Being a reputable dealer doesnt mean they have good installers, not being argumentative, just a fact. Im guessing you have the trunk open when you observe it dimming? Most trunk lights cut the positive with a switch and are grounded through the body, so maybe its just overly sensitive?
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
441
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
592
I have a 06 grand Marquis. Looking at either Kenwood or Sony Apple play. Is it worth have a floating monitor? Pros and cons?
840
ArcImpala
ArcImpala
Talontsi90
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
