01 Chevy Silverado under seat box designs
  • 5
Joe 537
I have 2 10” kicker subs in a factory box that does ok but I want more bass. I have seen a couple of trucks with downward firing boxes that are ported putting out killer bass. I can build a box I just don’t know what size or design to build. Any help with this will be very helpful.
Gonna sound muffled like a muffuletta sandwich...forward firing or remove back seat or nothing. I had a 03 Silverado ex cab up firing 2 12's  even with 3 layers of sound dampening on the roof wasn't good, only good sound I had in the truck was 2 forward firing 10" jl w3's.
I hate under the seat enclosures where there's not enough room to front fire. I've got 8.5 inches of height to play with. Tried down fire up fire all ******. Old ladies car so seats need to stay in. I've gotten to the point of sick of how it sounds. Either gonna figure out away to get 8s front firing or settle on 6.5s. I wouldn't waste your time op on down fire..
On a sealed sub box if I faced the subs up, I lost quite a bit of bass. Faced them forward, they worked great. On a ported box with subs and...
You need check connections at battery. You Can Check with a DMM of the Amperage at the Alt while running , and check the battery in the morning...
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
588
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
Joe 537
Joe 537
shredder2
    May 10, 2024
3toneEYZ
    May 10, 2024
