need amp for mids and highs budget minded
towncarblue
bx
i had a 2-channel amp , ppi phantom P600.2 connected to four 100w rms component speakers.
its going into protect mode as soon as it turns on. { I've had this amp for years }
i need a replacement. unfortunately, the prices for this amp skyrocketed. i paid around $100
for this amp , now its hard to find and they want over $200 for it.
the other one ive seen is the ppi  black ice but i dont know how good they are
i have a budget of about  $150-$200 for a NEW amp. it could be two channel or four channel .
post suggestions
i disconnected all speakers and turned on the radio, the amp still goes into protect mode .
each speaker is 4 ohms,
what is the ohm load with them all connected....thats what we need to know... more than likely you had it wired to a lower ohm (parallel) than the amp could handle and fried it...and will likely happen again with a new amp unless you know your load
I run the U.S. Acoustics Barbara Ann 4 channel amp and I will wager it would out do the PPI amp you were using. It can be had for $219 brand new @ this link - Barbara Ann
Check it out, the link gives its specs. It's a large and somewhat heavy amp. I have beat mine to hell and back and it barely gets warm... even over 90 degrees outside.
left... 2ohm (4ohm + 4ohm)
right..... 2ohm(4ohm + 4ohm)
on a two channel amp
i have a separate amp for my subwoofer { works fine }
load seems fine for amp...have you measured voltage at amp, checked your grounds, any loose connections....or f**k it and get a new amp or borrow someone elses and see what happens with it
i bought the Pioneer GM-D8604 . not bad at all. adjusted gain using a DMM .
i think this is louder. i can hear the voices/singing more clearly. had to adjust my old
eq band settings a bit on the highs.  i would recommend this amp to  friends
545
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
939
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
towncarblue
towncarblue
bx
towncarblue
Brendon Jenness
    May 8, 2024
    May 8, 2024
