Dunno what exactly i am doing?
  • 2
Tallsydawg6669
CarAudio.com Newbie
I have a sony xplod 1652z1000watt 2channel amp. I wanna know about rms in bridged mode (mono) 1channell i plan on pushin 2 pyleplw12bl 12" 800watt 4ohm subs. Will thos be ok? I think i read my subs can handle 400 watt rms but wont they be getting too much if the sony amplifier is putting up too 1000watts? Or 500? Im not sure exactly how this will be best? Wire the two subs on 2channells at 4ohm? Or parrallell the 2 subs to a bridged 2ohm channell?
I believe that's a 4 ohm stable bridged amp... so I wouldn't parallel 2 4 ohm drivers and expect it to last.
And actual power bridged at 4 ohm is 400-500 watts I think, but lose the Pyle's and get a decent 12... Idk... (maybe a Skar SDR-12 or an Sa-E12?) lots out there and you'll probably be ok. Really so many options for any budget but Pyle?.. I'm just gonna say NO
Those Pyle's will be peaky AF no matter what you do around 50-60hz so don't expect killer lows from those drivers.
400-500 watts on a single decent 12 in a correct enclosure can sound pretty good so don't get hung up on using those 2 boat anchors you got. The amp is adequate I'd use it , and get a better 12 then build a box to tailor it to your music tastes.
I had two of the Xtreme 12's and they were dual 4ohm. They read at like 3.5ohm per voice coil which is common.
9
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Can anyone in here participate in a short interview I am doing for school about the installation of a Kenwood DMX4070S in my 2005 Ford Expedition...
Tallsydawg6669
CarAudio.com Newbie
Tallsydawg6669
shredder2
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
