Kicker
  • 1
jay T ?
I have a question, and I need as much help as I can get.*
Here is what I have,*
Optima battery, Stock alternator of 150 amps, 4 gauge power and ground cable, 12 gauge speaker wire, Aftermarket stereo, Fosgate Punch 1000-1bd amplifier, and 2 12 inch l7 kickers. 2018 model.
When I higher my volume to like 3/4, both my subs rattle. Sounds like flapping rubber. I took my subs out of box, and they were still making that rattling/flapping sound. The subs are like 4 months old.*
I pressed on both sides of sub with fingers, and there was no scratching. Both subs are pretty firm. I checked the spider, and cone, and they both look perfect. All coils are on there right. No rips or cracks anywhere. I also tested all coils on both subs with multimeter, and all coils were reading at 3.7 and 3.8 ohms.
Is there anything else you guys recommend???
Oh yeah. And I also bought a Hifonics BRE20001.d and had it installed. Because I thought maybe my Fosgate amp wasn't working properly. But it's still doing the same thing. So it is doing same thing with both amps.
I bought the subs off a friend. He had them in his 2015 Camaro. He had them connected to his amp in his car. He let me hear them before I bought them. They sounded loud , and they didn't make any noise at all.
I bought them and I had them sitting for 2 months. Then I had them installed in my car. And that's when I heard them rattling.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
370
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
901
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
jay T ?
jay T ?
los angeles,CA
jay T ?
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
