debating between active and passive crossover
  • 4
millerb415
here is my set up infinity kappa 60.11cs front, kappa 6x9, alpine pdx-v9, and an alpine sub. was debating about whether or not to run the 60.11cs active on the amp or to run them passive using the crossovers that came with the speakers, and powering the back speakers also. what would you recommend?
If active is setup properly you’ll get better sound ..especially if you ditch the 6x9s..
347
Lower the ohm the thicker the wire. The higher the ohm the thinner the wire but will have more windings. Lower ohm coils have a slight edge when...
According to the Taramps site, there are three variants: TARAMPS SMART3 BASS 1 CHANNEL 3000 WATTS RMS 0.5 ~ 2 OHMS CAR AUDIO AMPLIFIER. TARAMPS...
They are good at the boom. Hard pounding lowend but lack at the upper notes. If you have a strong midbass setup they will blend fine. Buuut.. for...
13
millerb415
millerb415
los Angeles, CA
youdoofus
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
