6.5 sub
oryan20xx
WA
Looking to add some bass to my truck, planning on getting one 6.5 sub. Using an old Memphis 250d that is 250 watts rms. Subs I've found are:
Massive Audio Summo 64
CT Sounds Tropo
CT Sounds Meso
DS18 Elite Z6
Memphis PRX6D1
JL 6W3v3
Others?
Looking to add some bass to my truck, planning on getting one 6.5 sub. Using an old Memphis 250d that is 250 watts rms. Subs I've found are:Massive Audio Summo 64
CT Sounds Tropo
CT Sounds Meso
DS18 Elite Z6
Memphis PRX6D1
JL 6W3v3
Others?
how about the 6.5s that actually hit 150 db with just a pair on stock electrical, no big 3....
Its a series tuned 6th order 1 note wonder box. Basically a ported box feeding into another ported box.
I would look at digital designs, tang band and american bass offerings as well as what was mentioned above.
AAAAAAND this is what the owner has to say to you.
Guy actually has bandwidth down to the 28hz range with his vids on facebook. No changing ports, its the same box as the 150 burp. He did spend a whole year rebuilding over and over multiple times to get to this stage.
do u know what amp he's using cause that car has tiny alt i'm sure..
get this... the rear two channels of his sundown 200.4 which is 200 per 6.5
The meter is in the kick which imo is about as useful as looking at dynamic power ratings on amp dynos. You can tell its still peaky, I wonder how well the transient response is in person.
oh its hella peaky. It plays music but its definitely not a flat response by any means, not even close. Its a single octave wonder more than a one note wonder though.
wow lol i did that with 2 memphis 12's sealed on a orion 800.4 18 yrs or so ago. sounded great but 20db less of course.. yeah it's the small sub with low power and no electrical upgrades that make it impressive.. if he had 2k or even 500rms per sub with ho alt, 2nd batt and big wire and all wouldn't be quite as shocking..
I wonder how many woofers he went through during testing and I wonder what it meters sealed on the dash.
CT Sounds Tropo
CT Sounds Meso
DS18 Elite Z6
Memphis PRX6D1
JL 6W3v3
Others?
The DD LT is a beast it’s an old school sub that I’ve experimented with and they can be quite amazing ..I think I have a spare brand new one I may be selling soon
First and foremost is that the sub must be designed to work in a small enclosure. If not designed for it, you may end up with less bass than the...
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
490
https://www.parts-express.com/GRS-10SW-4HE-10-Paper-Cone-Rubber-Surround-High-Excursion-Subwoofer-4-Ohm-292-818?quantity=1 One of these in a...
347
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
490
oryan20xx
oryan20xx
WA
Papermaker85
    Apr 26, 2024
    Apr 26, 2024
