HELP with Comp. 6.5" Speakers--NEW Alpine Type X or JL C5650 or Infinity Perfect 600
socal2fast
So.Cal.
out of those I'd lean on the alpine. if the tweeter wasn't too big I'd suggest the new Memphis viv components but it's tweeter I'd much larger.
now while I'm prolly not 100% factually true it is my experience that smaller tweeters have issues crossing over at low frequencies say 2500-3000hz and that most people typically cross them higher at 2800-3500hz to prolong tweeter life.
if you have to cross that high the mid now has to make up foe it by playing higher in the band pass. some mids get muddy when you cross them high. typically a light paper/cellulose cone helps with this and a nice strong motor like the neo in the alpine should also help.
Hi Guys
I'm looking at these 3 sets that the local show has. I like that they have the 1" tweeters so that I can use them in the stock tweeter spot.
Witch of these 3 do you like the best and why?
Thanks for any info.
JL C5
C5-650 - Car Audio - C5 - Component Systems - JL Audio
Perfect 600
https://www.infinityspeakers.com/component-sys/INFINITY+PERFECT+600.html
Alpine Type X
https://alpine-usa.com/product/view/x-s65c
I tend to believe JL Audio backs up the complicated scientific principals when it comes to the higher end products.
Sent from my iPad using Tapatalk
171
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
189
420
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
265
socal2fast
socal2fast
So.Cal.
socal2fast
    Apr 26, 2024
    Apr 26, 2024
